l/h/rear suspension knock
hi guys, its been a while since i was on here, but i have just started to recommence work on my 71 sprint.The rolling chassis is completely new from the ground up, poly bushed all round, cv driveshafts, discs/calipers trunnions etc etc. the problem i have is that the left hand rear suspension knocks on rebound. i have new ttr shocks, locatones etc, but one thing i notice is that the top spring plate where the end of the spring sits is touching the strut on the inside when stationary with no load. have i mixed up the spring plates? ie wrong sides. are they sided or not? the top nut of the adjustable damper is up tight, any thoughts would be appreciated, ian.
- bmcman.ie
Ian
the top spring plates are same both sides, are your springs standard dia
When you fit them you must ensure that the spring ends are located in the plate recesses top and bottom before tightening the top nut
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
We had a knock on one side of the rear suspension, it took a bit of finding but it was the damper insert catching on the bottom of the strut housing. Solved by removing insert and cutting a thin piece of rubber and dropping it down the strut. Refilled with a little oil and rebuilt unit and it's now fine.
TonyR
TonyR
1966 S3 FHC Medici Blue
- tonyr27
