S4 Ride Height & Suspension Tightening
Posted: Wed Sep 09, 2015 5:17 pm
Having re-bushed all my suspension joints with new rubber bushes I now need to finally tighten all the wishbone nuts and bolts. My intention is to carefully jack up the car and support it under the front and rear wishbones as near to the wheels as possible and spread the load with wooden blocks so as not to stress or damage anything. I would then remove all the wheels and this will give good access to all the nuts/bolts for tightening. Is it worthwhile adding a bit of extra weight in the seating area to simulate someone sitting in the car so that the suspension is compressed a bit more.
Is the above a good idea as I can't see an alternative to be able to access all the suspension points?
Also, with my car on the ground the distance under the sill is 6 1./4" and the adjustable spring platforms are at their lowest positions. Is there an ideal ride height for road cars?
Many thanks for any comments.
