Replacement Brake Pads... which?
Posted: Thu Sep 04, 2014 9:03 pm
I have a '72 federal Sprint which comes with dual system brakes (split front/back) & no servo.
The master cylinder (0.700" in diameter) was rebuilt in April, all caliper pistons are free & there is no air in the system.
The brake pedal effort required to stop the car is huge. The first time I drove the car I needed clean underwear the first time I needed to do a quick stop, I can only just lock the brakes up, I'd estimate that I'm using 250-300 Lbs force on the brake pedal when I do a quick stop. Unfortunately I do not have access to another Elan so have nothing to compare it against...
Given that everything seems to be in order with the rest of the brake system, I can only assume that the pads are too hard.
Anyone have recommendations on brake pads to use? I see older recommendations on EBC Greenstuff & Ferodo DS2000s, but not sure if this was for a Servo-less car.
Any advice appreciated. I'm coming to England in a couple of weeks & will be stopping by Mr. Matty or can source locally (USA.)
p.s. My hand brake works perfectly... go figure!
