a bit of a lean.....
hi guys, me again...!!
had the elan for a few months now, and no real problems......however, yesterday parked across a slope, and noticed on returning to the car that the driver's side rear wheel arch seemed to be a couple of inches higher than the other.
checking at home on level ground, driver's side arch is indeed 28mm higher, front about 8mm.
now, before I jack her up to inspect, what am I looking for?
notes; no knocks, clunks or rattles from suspension, cornering and straight line stability fine, i.e. no symptoms.....
PO installed TTR gazmatics on front some years ago.......
could it be twisted chassis?
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
Hi, my S3 had a bit of lean, not 28mm. That was caused by the PO who was not able to put the body straight on the chassis and put some washers more on one side. As simple as that. Removed the washers, body was leveled on the chassis.
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC (left window stuck)
1969 S4 FHC (waiting for return pickup)
Brian Bucklands 2nd edition available ! Look here: https://theelanman.com
- gherlt
Stick the equivalent weight of the driver in the seat and re-check..
thanks for that john!!!
so then I would only have a lean when carrying a passenger......[hmmm, my wife doesn't normally like her weight being discussed
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Fred, get a plus 2 and make her sit behind you
Kev
Kev
- KevJ+2
If you want to carry passengers,get rid of the Lotus and buy a train ticket...
Tickets please!!
ps. If that's the front, how does the driver see where he's going
- KevJ+2
