Front Wishbone Brackets
Tue Feb 25, 2014 6:03 pm
by William2
My S4 Elan has front rear lower wishbones with small brackets welded on with access hole for suspension nut and a hole above this as shown in the picture. Are all Elan wishbones like this or are mine unusual as I'm not quite sure what purpose they serve? Also, on full lock with the suspension fully extended the lower caliper retaining bolt head hits the top of the bracket. I am also assuming I have put these wishbones in the correct positions or should they be on the front?
Re: Front Wishbone Brackets
Tue Feb 25, 2014 6:18 pm
by UAB807F
Hmm, that's a new one on me. When I first read your post I thought it might be for a stiffener as wishbones have been known to crack or flex, but having looked closer at the photo, well, I'm stumped.
As you say, they do strange and if they do impeded the amount of lock you can achieve then I'd be tempted to take them off.
Random thought - could this be someone's way of restricting the steering lock for extra wide wheels & tyres ? I'll look forward to seeing what the rest of the folks think.....
Brian
Tue Feb 25, 2014 7:25 pm
by Chancer
So the photo is of the rear of the wishbone?
Possibly tie down attachment points for a dedicated race trailer.
My first thought was mounting points for a towing A frame but they would need to be on the front, at a different angle and all the ones I have made have used the inner pick up points.
Tue Feb 25, 2014 8:10 pm
The upper hole is quite small, I guess some kind of support for cable or brake flex line. Possibly to keep it out of the way of a larger set of wheels
Tue Feb 25, 2014 8:28 pm
by marklowe
Are the brackets fitted to all 4 lower wishbones? Would they make more sense if they were fitted the other way up, with the brackets hanging down?
Tue Feb 25, 2014 8:42 pm
by richardcox_lotus
Never seen this before. As an aside anyone know if standard pattern front wishbones are available ? when I asked Miles in November he said they were none around, and I don't want the Spyder tubular ones.
Tue Feb 25, 2014 9:08 pm
by marklowe
Original style wishbones are available from Kelvedon & Tony Thompson, and it?s always worth giving Susan Miller a call.
Tue Feb 25, 2014 9:54 pm
My guess would be they were meant to point down and where used for mounting a custom antiroll bar.
Wed Feb 26, 2014 10:09 am
by Chancer
I think that you are the prize winner
Wed Feb 26, 2014 5:13 pm
by William2
Thankyou, gentlemen, for your thoughts. Great to be responsible for a mystery question! I took all the lower wishbones off today and swapped them around so that the brackets are pointing downwards and are now in the forward position. I think I would also agree that they are some sort of hold down facility when the car is being trailered.
Wed Feb 26, 2014 7:21 pm
by Chancer
Try swapping them side to side and they might morph into anti-roll bar attachments.
The angle of them should give you a clue.
On reflection I can see the wisdom in having tie down point outboard on the unsprung upright, the vehicle will be able to bounce up and down on its suspension without moving or straining the straps similar to the ratchet strap wheel hold downs used on flat beds.
