Steering Rack Height
Posted: Wed Jan 08, 2014 4:07 pm
The steering rack loosely fitted to my Elan chassis has no shims on the mounting platform. The chassis has been powder coated by the previous owner so I cannot see any shim size marked on the chassis. Did Lotus tend to mark the shim sizes in black marker pen or might they have been stamped on in which case they might still be underneath the layers of paint?
When I refit the rack I am going to use some aftermarket solid alloy mounting blocks and I was wondering what the best method would be to position the rack at the correct height. I assume that the alloy blocks would be made to the same tolerance as the original Triumph fittings.
