Optimum suspension setup for an S4 elan
You have quite a few TTR bits. TTR do a spec sheet for their 26R set up which I suspect they would give to you if you pointed out your purchases. It would prove interesting to compare to the DB manual set up. You'll find they are not too dissimilar.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
I will check out the TT site for details. My first job is to dial in ride height, The manual says 6" and 6"
I'm a little low at the front (5 3/8") and high at the rear. (6.75") Once i get that set i'm of to have the correctly aligned, and then i will see how we are. But it does sound the thicker front ARB is being recommended by most. So i may fit that also.
James/
James/
holywood3645 wrote:I will check out the TT site for details. My first job is to dial in ride height, The manual says 6" and 6"
James/
They don't publish it, you need to ask!
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Rohan,
When you say install 20mm spacers for rear Aeon's, of what are the spacers made, or where can they be obtained?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
A sketch and picture of the Aeon's would help.
James
James
James
Where are you measuring the ride height at the front? I recently installed AVO adjustable height front shocks with 115 lb. / 12inch long springs ordered from Dave Bean. I cannot lower the springs quite far enough to get the lower control arms horizontal. I have 155mm X 80 tires and 5 3/4" clearance at the front sill. I am optimistic things will settle in after use enough to allow me to get the correct height. I remember 5 1/2" as a front sill height reference. I have not yet had a chance to evaluate the handling.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
I figured I'd add to this thread since it seems a very similar setup (Bean fast road) to what I have on my car. The questions I have are about the rear bump stops. My setup is about 3/4-1" lower than stock.
How much damper shaft length should there be between the top strut nut and the bottom of the bump stop? This dimension roughly equates to suspension travel before the bump stop comes into play.
Rohan recommended decreasing this dimension by 20mm in the reply above, but should this be done if the car is also lowered?
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
snowyelan wrote:I figured I'd add to this thread since it seems a very similar setup (Bean fast road) to what I have on my car. The questions I have are about the rear bump stops. My setup is about 3/4-1" lower than stock.
If the suspension is 3/4 to 1 inch lower then the bump stop spacing should be about right without spacers. I run my rear suspension at close to it's normal height and the car lowering has been done almost completely with the low profile 175/60 tyres. Hence the 20 mm spacer I added. I would need to check the gap at normal ride height which would be hard at present as the car is on the MaxJax with the engine and gearbox out ! But from memory its about 30 to 35 mm with the spacers. I can check the gap at full droop and calculate what it would be at normal ride hide when i get a chance in the next couple of days
I currently have 30mm of spacers with a 15mm one above the Aeon and 15mm one below. The suspension is lowered by around 10 to 15 mm and the gap at normal ride height to the Aeon spacer about 15mm and 60 mm at full droop with the limited droop Koni shocks from TTR. I am using 150 lb/in rear springs
For a road car the Aeons would come into play a little early I suspect with this set up, especially if you have softer springs hence I would try 20 mm of spacer. I have them top and bottom as they help protect the end of the Aeons from getting chewed up. I had a single 20mm spacer on the bottom of the Aeon a number of years ago when I was using 110lb/in rear springs and the car was more of a road car
Lots of variables so to some degree you need to experiment to find out what works for you with your car, tyres, other suspension variables and driving style. At one point i tried a stiffer Aeon as there are a couple of load ratings and Lotus used the softer one. But the stiffer one just gave to much of a spring rate transition when it came into play so I went back to the Lotus one
Picture at normal ride height below , hard to see as spring coil in the way but around 15mm gap from top of shock to spacer below Aeon
At full droop its a bit easier to see
The spacers I used are actually poly bushes. I just went through the catalogues from the makers until I found a suitable thickness and inside and outside diameter. The OD taper you see in the photos also fits nicely to the smaller diameter top of the shock and larger diameter bottom of the Aeon. Lotus used aluminium for the 20 mm cylindrical spacers they added on the later Plus 2 these has a small lip on the bottom that could be peened over to hold them onto the top of the shock so they did not rattle, they did however tend to chew up the bottom of the Aeon.
