Plus 2 Front Suspension Refurbish
I'm planning to strip and refurbish the front suspension on my recently acquired Plus 2.
My plan is to re bush wishbones and anti roll bar, powder coat wishbones, check trunnions and replace ball joints.
Looking for suggestions as to which springs and dampers to use, existing are red but mainly rust in colour.
Any other suggestions for what to check while doing this work.
TonyR
TonyR
1966 S3 FHC Medici Blue
- tonyr27
I'm very happy with my Tony Thompson spings and dampers (purchased through Sue Miller).
After previous ventures into spings and dampers the above just felt 'right' as soon as I went for my first drive with them.
Peter
Peter
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
Hi Peter,
I am interested in TTR front suspension on my +2 as have fitted TTR springs etc on the rears, but before I do I would like to have an idea how the car would sit as well as so many +2's look like they are on steroids at the front having had new springs.
Could I ask you to tell me the height from the ground to wheel arch lip.
If you could it would be greatly appreciated.
Many thanks
Peter
Many thanks
Peter
1968 +2 BRM
- Peter +2
[quote[quote="peterako"]I'm very happy with my Tony Thompson spings and dampers (purchased through Sue Miller).
Peter
Thanks Peter, I reckon the TT ones are what I will go for.
Peter
- tonyr27
I went for workshop ride height (I thing 6 - 6.5") at crossmember.....this is a measly 4 or so inches exhaust clearance!
Car sits nice and level with about 'three fingers' breadth clearance at the wheel arch.
They are adjustable, so as has been said before....ride height of your choice.
Peter
'73 +2S 130/5
'73 +2S 130/5
Hi Tony
I used Protech dampers when I rebuilt my +2's front suspension. These were recommended to me by Spyder. Alloy bodied, adjustable seats, adjustable damping, competitive price. I've been very happy with them.
As usual no connection, just a satisfied customer.
Good luck
Andy
Good luck
Andy
andyhodg - Third Gear
I have TTR insert at rear with original springs (no adjustable height), and Protech at front with adjustable height.
First: only measure ride height when car is settled, which will take a couple of miles/days.
Protech on front are of good quality, but it did not have a positive effect on ride quality. It is a big difference compared to the original Armstrong shocks. However they do limit roll and they are good for track use.
The ride height in front will have a big effect on weight distribution/corner weight. When I first set the front too low, my car became much oversteered and it was very difficult to control back end when driving on the edge,
/Ulf
/Ulf
1974 Lotus Elan +2 130/5
- Uboat
TonyR
If your oroginal shocks were painted red, it just possible they might be Koni Classics. If that's the case (and assuming you haven't already bought new ones) you might want to consider getting them rebuilt/refurbished. Konis were very good shocks but sadly they're no longer available.
Andy
Andy
- andyelan
Thanks again for the advice.
Just before Christmas I bought a pair of TT comfort damper & springs. Started strip down, going to get the wishbones powder coated and generally tidy up the calipers etc.
Andy I think the existing pair are Koni, might put them on EBay, they're a little rusty but I believe the dampers are ok.
Can anyone advise me if the Spyder tubular wishbones utilise the same bushes as the original Plus 2 ones?
TonyR
TonyR
- tonyr27
