Elan Front Spring Compressor
Here is mine. 1/2" plate, 5/8 all thread. I only used two threaded rod because of the thickness.
The safety clips are there once the spring is compressed and the plate taken up so the keeper can be installed. The clips are just to hold the spring, not compress it. The plate does that work.
I lay the tool on bench on it's side and place a solid bar inside the tool and spring for 100% safety during compression.
"Be Polite, Be Professional, But have a plan to kill everyone you meet"
General "Mad Dog" James Mattis United States Marines
- cal44
Well, found my solution. I had a cheap motorcycle compressor around like
http://www.amazon.com/Motorcycle-Shock-Coil-Spring-Compressor/dp/B004NV23KC
that was way too small, but I took it apart
Two of the hooks have 14MM threads, the other two are just holes. I got some 14mm rod, cut in three pieces and welded nuts on the end. Got a standard pipe fitting (I think for 1" ID pipe) then put the two threaded little hooks on the first two rods. I welded a 14mm nut onto a third hook, and threaded it on a third rod.
Worked great. Used a power driver on the nuts, just kept walking around to keep the spring straight.
J Geezer
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
(Past MGA, MGB, TR6, AH 3000 BJ8, XR4ti, BMW E39 540i/6, Lola T644 ... )
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
JGeezer - Second Gear
My preferred solution is dead simple, a pair of ratchet straps.
At a pinch you can get away with just these but its hard work compressing the spring, you can do it on the car with an assistant putting their body weight on the vehicle but the following is my preferred and safest method.
To compress the springs either on or off the damper I use my drill press the ratchet straps being already threaded into place, the gearing makes it easy to compress and the spindle can be locked leaving the spring secure and both hands free to take up the slack on the ratchet straps.
I have done the above on dozens if not hundreds of coil over shocks like the Elan fronts, I have not done a rear strut but expect my floor drill press would handle it easily.
- Chancer
sorry to revive a nearly two year old thread, but I've been rummaging through the history and have ended up confused. I'm looking to create a tool to compress my front springs, having looked at a lot of forum users' creations, I don't undersand how the collet is removed if a plate is coming down on top of it.
I understand the top plate will have a hole in it, does the collet fit through this hole? there doesn't seem to be a lot of space around my collet.
am I making sense?
-confused in Melbourne.
am I making sense?
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
ok now that I've done it i just thought I'd clarify for anyone who's mind works like mine.
there does need to be a hole at the center of the top piece that the collet JUST fits through.
also a note of warning, when de compressing it is possible for the spring to get stuck on the top perch of the shocker, and your compressor is no longer holding the tension...a very dangerous situation....keep watch for this!
36/6612
dgym - Third Gear
