Top shock absorber nut
Hi Franck,
Do you have the original shock absorbers with a shouldered castellated nut ? They may not all be the same of course but mine were certainly 15/16". If you have replacement shock absorber inserts fitted they will probably be metric threads with nyloc nuts.
Can you measure the size across the flats of the nut and compare it with these charts - it should give you the correct spanner size.....
http://www.fairburyfastener.com/xdims_nuts_coarse.htm
http://www.fairburyfastener.com/xdims_metric_nuts.htm
S4 DHC
S4 DHC
- oldelanman
Sorry Franck but I don't have any other suggestions.
Maybe the Plus 2 is different from the Elan ..... perhaps another +2 owner will be able to help.
S4 DHC
S4 DHC
- oldelanman
Cut a slot wider than 15/16" in a piece of card that you can push over the nut to measure its size. There should be a split-pin through the nut which, as oldelanmans's picture shows, should be castellated to take it.
When you undo the nut the damper rod will probably rotate so either get a spanner on the flat machined near the top of it (I think) or if you are going to scrap the damper grip it with a Mole wrench or similar.
Good luck
Good luck
Meg
