Larger Sway Bar
Was wondering if anyone has sourced a larger front bar for the +2.
Have a spyder chassis with mounts for the rear bar and was considering trying a larger front, small rear but do not see anyone showing them
USA based would be preferable as the shipping gets pricey
- gus
Ok......you may be thinking backwards , you may want to. Transfer weight to the front suspension that allows the chassis to To transmit the energy to the front suspension causing the front loaded side to collapse keeping both front tires on the road and avoids 3 wheeling and makes the tires work so You can keep the power down in corners ..so. Big bar at the back and small one in the front.....ed
Lotus knew what they were doing and got the suspension design pretty right for the tyres of the day. Modern tyres are stickier and most cars need a little stiffer suspension and roll stiffness to extract the best out of them.
The Plus 2 with its wider track and longer wheel base needs less stiffening than an Elan with modern tyres and for normal road use I have not bothered stiffening up my plus 2 despite running modern track day tyres such as Dunlop DZ3G or Yoko A048R on it for normal road use.
If I was doing anything I would try a 7/8 inch front roll bar at the front first and then a 50% rate increase in front and rear springs, finally I would try a light rear bar. Spacing down the rear Aeon rubber springs / bump stops so they come into play earlier is a good substitute for a rear bar to stiffen the rear roll. Lotus put 40mm alloy spacers on the later plus 2's rear struts and this is a worthwhile addition for both handling and for when you have extra weight in the car. A lot of cars have lost the Aeon springs over the years on the rear struts as people don't understand how critical these are to the overall handling, Lotus did not put them there for decoration
Quite the opposite I like to drive forward very quickly ...don't believe me?? Screw your front suspension down with weight. Transfer nice and tight so the lthe front wheel lifts off the ground in a fast turn for over steer ....and.see....bring fresh undies ..Ed
Right Dude ....when you write off the Car sell me the dash pad ,,,,Ed
when you write your book revolutionizing automotive suspension design, you let me know. Till then the larger bar in the front, where the load is, and the smaller in the back will have to do.
I take it you know of no sources of sway bars of any dimension anyway
- gus
twincamman wrote:Right Dude ....when you write off the Car sell me the dash pad ,,,,Ed
If you have a cheap source of whatever it is, let us all know!
RogerFrench - Fourth Gear
Welllll if you know all the answers why did you ask the question????? but the suspension must work that's why Lotus put low pound. Springs on the car.....but please your self ....
