Minilite SS inserts
Hi All, I got a set of minilites and separately, four steel inserts. Any body have experience pressing these into the wheel centre? I am torqueing them at 180 lb/ft but they dont' 'seat' evenly. Is there a trick to this? Scott
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
I'd check the rim offset is correct before applying too much force- the centre lock spinner base might be bottoming out before it's sufficiently tight. I might be misinformed on this but if your rims are like mine (minilites also) the ss inserts should just push in by hand.
john
john
- worzel
Hi John, the spinner doesn't come close to bottoming. I have got plenty of thread left. My guess is that the painted surface is just enough to interfere with it slipping in however, this paint is very hard (likely powder coated). Not sure why they don't press these in at the factory, but Minilite just said torque them down until they seat. Scott
CG901 - Second Gear
