Elan and +2 front k/o hubs
Although the part numbers are different, e.g. 050CXXX (Elan +2) and 036CXXX (Elan), are the front k/o hubs interchangable? I know the brake rotors and calipers are different. Thanks.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
Plus 2 hubs are wider - discussed here.....
lotus-suspension-f42/are-elan-hubs-the-same-hubs-t20152.html
S4 DHC
S4 DHC
- oldelanman
don't forget that they are handed also. Red left side lefthand thread and Green right side righthand thread.
I say this because when i was in New Zealand this Year i saw 3 Elans and 2 of them had the hubs fitted on the wrong side Maybe things are different down under
Alan B
Alan B
- alan.barker
Roger and Alan, thank you. The exercise wasn't a total loss as I did pull the vertical link, and steering arm from the +2 that will fit the Elan. Now for sale is the +2 RH KO hub, caliper bracket and dust shield.
CG901 - Second Gear
