Rear Disc thickness, any new knowledge?
Posted: Fri Mar 08, 2013 1:08 pm
Hi I've just noticed, now that the body's off, that the two rear discs are quite different in thickness.....O/S is 5.5mm and N/S is 11.4mm
that's too much difference to be put down to wear....clearly they are different parts. And will be unacceptable to use together.
Can anyone advise which is more likely to be the correct thickness?
Robert
Robert
