Page 1 of 4
Oval rear control arms
Sat Dec 29, 2012 1:13 am
by Harvey
Ten years ago I purchased a +2 Spyder chassis and Spyder non-adjustable rear control arms. The arms' tubes were oval and not round like my original control arms.
I just had my rear toe measured by a laser alignment machine at the local tire shop. On the left side I had .08" of toe-out and on the right had .01" of toe-in. I want to change the left side toe-out to toe-in and increase the amount of toe-in on the right. I am aware that Spyder and Kelvedon now make adjustable rear control arms that extend the rear tube via a turnbuckle to permit toe adjustment. I am also aware of an extensive past discusssion on this site titled, "adjustable rear control arms" wherein several clever Lotus owners have fabricated tube inserts and threaded rods to do what Spyder and Kelvedon have done, perhaps better.
My question for the forum is whether anyone has modified rear control arm tubes that are oval rather than round? If so, how did you get the round tubular inserts to match up with the oval tubes?
Lee
Re: Oval rear control arms
Sat Dec 29, 2012 3:50 pm
by stevebroad
Who in their right mind would adjust to-in/out by stressing the joints on the A-frame? IMO, this is utter incompetance and bloody dangerous.
The simplest way, and it works on round and oval tubes, is shown below. The to-in/out can be adjusted insitu as the rod end will turn within the chassis mounting tabs. You will, however, have to make spacers to take up the difference in width between the original bush and the new rod end.
Sat Dec 29, 2012 6:32 pm
by spanner
Lee
Hi Lee,
A special flanged barrel is used on aircraft streamline tubing for this purpose. The larger weld area greatly increases the strength. The open end can be tapered and welded.
http://univairparts.com/bulletin_direct ... 200120.pdfhttps://www.aircraftspruce.com/pages/lg ... bsets3.phphttp://www.ebay.com/itm/Piper-Style-5-8 ... 0592946916Good luck with your project.
S-B
Sat Dec 29, 2012 8:17 pm
by Harvey
Steve,
Thank you for your response and the clear pictures of your modification to your control arms. The machinist/welder who is going to modify my arms also questioned the stresses placed on the arms by the turnbuckle expansion setup even though I told him that Spyder and Kelvedon have been selling this type of adjustable control arms for years seemingly without safety issues. The machinist is familiar with fabricating suspensions for formula cars and the use of rod ends to adjust rear toe. We discussed rod ends and he did not think they were the best choice for street cars and prefers to stay with the metalastic bushings. I wil, nevertheless, forward your response on to him.
S-B
The flanged inserts you have pointed me to look like they would mate up nicely to my oval arms with a bit of careful welding. I will pass this information on to my machinist. Thanks for the links to the inserts and to the instructions for attaching them to the arms.
Lee
Sat Dec 29, 2012 11:57 pm
by stevebroad
Just because they haven't had a problem doesn't make it a good idea. Would ACBC do it? I don't think so.
You can do the same with a metalastic bush, as shown below:
However, you will have to remove both chassis bolts and drop the arm to adjust as it won't turn in the chassis mount.
With 3 bushes remaining I don't think one rod end will make a noticable difference to the noise or feel.
Sun Dec 30, 2012 3:14 am
by ceejay
The adjustment of the rear A arms via the left hand - right hand
threaded adjusters is acceptable engineering practice. The thing that
most people over look is the small amount of + or - movement required
to achieve correct toe settings, on the adjuster it amounts to as little as
three quarters of one turn.... in other words, the A frame hardly moves,
and is certainly not subject to excessive stress or strain.
If the A arm requires a large amount of movement to obtain correct toe
settings it was probably badly made in the first place, or it has suffered
a decent whack in it's past life.
But it does not matter how expensive or accurate the jigging system being
used is during A arm fabrication, the A arm will pull or move slightly, it is a
natural thing with metal, during and after being welded.
Whether new A arms are bang constructed, or an old pair is being modified,
there is a lot of careful fabricating work involved, but the results speak for
themselves when the final laser alignment is completed.
The metal used to construct A arms is nothing more than 7/8" OD mild steel ERW
tube, sure, if one wants something a bit more exotic, build them from DOM tube,
or choose 4140 Crmoly, but then, it is quite expensive to buy, and more
difficult to weld and TIG is the only way to go.
But with ERW mild steel tube, nickel bronze weld is all that is required.
I wont get into the jigging and the fabricating set up, as that is a story
in itself.
Ceejay.
Sun Dec 30, 2012 8:48 am
by stevebroad
If you are happy to add additional stresses to an already stressed component, then go ahead. It looks neat and adjustment is easier as there is no dismantling required. However, the race car builders I have spoken to consider this method to be bad engineering by people who don't really appreciate the stresses involved, so I took their advice and did it properly
(lMO)
Sun Dec 30, 2012 9:59 am
by ceejay
One could argue the pros & cons on this till the cows come home.
If you are happy with a rattling rose joint A frame adjuster on a
road car, that's fine.
It's horses for courses... normal road driving does not
stress components like the stresses that are generated under
race conditions.
Even with this A frame adjustment mod, the A frames wont break,
you would be surprised at just how strong they really are.
Sun Dec 30, 2012 11:22 am
by miked
As a point of interest Steve, have you ever put a hacksaw through one of the rear tube? I have and they generally spring apart leaving a gap larger than the hacksaw blade. I know jack about metals and stress but would say that they are already stressed by the original build with the heat treatment that they receive. I ran an S4 for a number of years with the turnbuckle adjusters. I also run a Plus 2 with a set of these. The tweak from what would be considered normal is very tiny to give correct Toe in. It is only done once. I will be having a check for cracking at the front tube joints.
Where would you be considering the stress point? the front outside joints since most corrections are to toe in after the frames give toe out? I am only asking so don't take this the wrong way? Project/track S4 in build has rose jointed TTR frames.
Ceejay, Re: 1 mm toe out. Correct toe is "in" is it not, not toe out? Thus allowing flex to straight. I usually set about 1.5 mm per side giving 3 mm overall (road use).
Sun Dec 30, 2012 11:50 am
by worzel
Some interesting comments on this issue. I wasn't too keen on the turnbuckle system so I had a pair of new frames made by TTR. They use the original bushes but adjust on the car- one on each frame uses a locknut only so the initial setting on this needs to be accurately done. The other bush is adjustable on the car- the threaded part runs thru an unthreaded tube and is locked via two locknuts, one either side of the mounting. I'll post a picture later to clarify things.
Sun Dec 30, 2012 11:53 am
by stevebroad
miked wrote:As a point of interest Steve, have you ever put a hacksaw through one of the rear tube? I have and they generally spring apart leaving a gap larger than the hacksaw blade. I know jack about metals and stress but would say that they are already stressed by the original build with the heat treatment that they receive. I ran an S4 for a number of years with the turnbuckle adjusters. I also run a Plus 2 with a set of these. The tweak from what would be considered normal is very tiny to give correct Toe in. It is only done once. I will be having a check for cracking at the front tube joints.
Hi Mike
A valid point. If buy cutting the tube you release any stored stresses, putting an adjuster in the cut bar would not add any additional stress to what was there originally. I therefore retract my previously stated strong views against the system. However I still, personally, prefer the rod end solution as the A-frame bars stay as one piece.
Due to the obvious shortcomings of the original design with regard to twisting we have attempted to strengthen our frames. Any thoughts on whether we will be successful?
Sun Dec 30, 2012 2:04 pm
by TurbineHeli
Hi Steve, what is the purpose of the plate with 6 holes?
AMA
Sun Dec 30, 2012 2:08 pm
by stevebroad
Anti-roll bar (or sway bar on your side of the pond).
Sun Dec 30, 2012 3:14 pm
by GrUmPyBoDgEr
Sorry Steve but all I can see is a load of extra "un-triangulated" triangles adding no further stiffness as such.
Anyway the purpose is location & I don't recall any earlier discussion on the lack of stiffness in those frames.
Spyder claim improved stiffness with their ovalised tubing but don't explain what that brings with it.
Sun Dec 30, 2012 4:17 pm
Is there not a snag with the rose joint method in that it can only be moved in increments of a half-turn of the thread?
