Broken Spring
Sun Sep 09, 2012 9:15 am
by mikec2126
Driving my +2 from the garage this morning, heard a pinging noise, found this broken spring on the deck.
Does anyone recognise its (normal) location?
Re: Broken Spring
Sun Sep 09, 2012 9:35 am
by Higs
If yours is an early +2, then that looks like your bonnet counterbalance spring (goes between the front bar of the bonnet and the front of the chassis.
They were ditched after chassis 0720.
Richard
Re: Broken Spring
Sun Sep 09, 2012 9:42 am
by mikec2126
Higs wrote:If yours is an early +2, then that looks like your bonnet counterbalance spring (goes between the front bar of the bonnet and the front of the chassis.
Richard
Many thanks Richard
My +2 is a later 1974 +2s 130, that does sound that it could be a related issue though, will investigate!
Re: Broken Spring
Sun Sep 09, 2012 11:09 am
by Robbie693
Looks like the return spring on the clutch release arm to me...
Robbie
Re: Broken Spring
Sun Sep 09, 2012 11:13 am
by fatboyoz
Mike,
I have an S4 and have been recently been working on the clutch hydraulics. The spring looks a lot like the clutch slave cylinder return spring. It is located between the clutch lever in the bellhousing and the "ear" on the slave cylinder.
Colin.
mikec2126 wrote:Hi
Re: Broken Spring
Sun Sep 09, 2012 7:49 pm
by mikec2126
Thanks for that guys, that indeed looks like the missing item.
Re: Broken Spring
Sun Sep 09, 2012 11:00 pm
by AHM
Pull the last coil straight and bend the end into a hook with pliers...
Then put it back where it came from!
Re: Broken Spring
Mon Sep 10, 2012 2:10 pm
by mikec2126
AHM wrote:Pull the last coil straight and bend the end into a hook with pliers...
Yes, thanks. Will do that
Re: Broken Spring
Mon Sep 10, 2012 9:45 pm
While bending a new hook from the broken end of the coil is a good temporary repair I would order in a new one also. The spring may have more than one fatgue crack in it and it may break again soon at the next crack. Cold bending the spring may make it even more likely to fail soon.
