I don't recall ever having seen a ride height specification measured in relation to the sills. The archived discussion on ride height describes the factory method I am familiar with:
Ahh yes the chasis closing plate bit was what I had remembered seeing.
As you say it is not that helpful. Looking at the diagram for the front
suspension I assume that it has been drawn with the suspension in its
neutral position. If so it would appear that the bottom wishbones should
be level at normal ride height. I can now check / adjust the ride height
with a spirit level.
Franklin R. Jones wrote:
Quote:
On Mon, Jul 12, 2004 at 08:31:31PM -0000, stevew_w wrote:
> You have spent too long on google. Yes I know Steve Waterworth is an
> unusual name but it is not me who messes about with Skodas. Although I
> do have an interest in rear engined cars of a different type, see
www.stig.uklinux.net>
> Still need to know the right ride height and where to measure it
> though. I am sure I have seen it in the workshop manual but I am
> damned if I can find it at the moment.
only mention I've seen in the workshop manual is under Section
C - Front Suspension (page 4 of my UK vers dated Oct 72) where it
talks about blocking the suspension at 6.125" front(15.5cm) and 6.00"
rear(15.2cm) beneath "front lower wishbone fulcrum and beneath each
rear chassis leg adjacent to the wishbone pivot and NOT touching the
pivot." prior to adjusting the front-end (tow-in/caster/etc).
though it implies that they car should be weighted to get it
to the blocks so that implies that unloaded it would be higher.
Tech page also states that the design ground clearance is 6"
but no detail on what that means in real world terms.
fj..
