Extension Housing Bush
Can anyone tell me the length of the bearing/bush fitted to the 4 speed extension housing?
Thanks - Richard
Thanks - Richard
- ardee_selby
I would guess an inch and a half.
Gary
Gary
piss-ant wrote:I would guess an inch and a half.
Gary
Thanks Gary,
I knew you would be able to help...
Cheers - Richard
- ardee_selby
You may find on inspection IE, inserting the gear box end of the prop shaft splined drive into the rear extension
that the inner bush may not show much wear at all. After reading the post above I thought I better check
mine because I have just replaced the seal after having made a special extraction tool;
Tool To Remove Gear Box Ext Housing Oil Seal
elan-f15/tool-remove-gear-box-ext-housing-oil-seal-t25017.html
So after mating the prop shaft inner splines to the extension housing, the play was minimal,
about 2thou max... which surprised me as the bush is the original and I have never replaced it,
so check the actual wear before you get involved in extracting the seal and the inner sleeve
bearing.
bearing.
- ceejay
Users browsing this forum: shaun and 25 guests
