Trigger wheels
Sun Jun 12, 2011 6:50 pm
by pauljones
For those that have efi,how and what have you used as a trigger wheel, I have looked at various sites and can't decide.I do have a cvh ford that has a lower pulley wheel and looks like it could be useable.I'll be using an emerald ecu if that helps
Any ideas guys?
Re: Trigger wheels
Sun Jun 12, 2011 6:59 pm
Paul
You could try this...
with the added advantage of lightened flywheel..
Re: Trigger wheels
Sun Jun 12, 2011 7:09 pm
by bob_rich
Hi Paul
I had a Ford 36 pulse wheel fitted to the crank pulley and will be mounting the sensor broadly speaking in the position shown. After installation will cut of a tooth for the reference position of around 90 degrees BTDC on cylinder 1.
hope this helps best of luck
Re: Trigger wheels
Sun Jun 12, 2011 7:11 pm
by bob_rich
Hi Paul
hope this helps best of luck (oops 4 got picture sorry !)
Re: Trigger wheels
Mon Jun 13, 2011 12:43 am
by memini55
Paul,
I bought a lower pulley from QED and they also have the bracket for the pickup which bolts to the lower front pan and comes with spacers for the bolt up. I am using a Megasquirt and ground off a tooth on the pulley for the missing tooth.
Re: Trigger wheels
Tue Jun 14, 2011 11:21 am
by bcmc33
Paul,
QED do a nice trigger crank pulley.
http://qedmotorsport.co.uk/qed-shop/lot ... y-36-teethYou need to remove a tooth in the location that suits where you put the sensor. This is mine--
QED also supply a sensor bracket, but I made mine to suit a 2 point fixing.
Re: Trigger wheels
Fri Jun 17, 2011 3:50 pm
by pauljones
