Lotus Elan
Trigger wheels
PostPost by: pauljones » Sun Jun 12, 2011 6:50 pm
For those that have efi,how and what have you used as a trigger wheel, I have looked at various sites and can't decide.I do have a cvh ford that has a lower pulley wheel and looks like it could be useable.I'll be using an emerald ecu if that helps
Any ideas guys?
pauljones
PostPost by: john.p.clegg » Sun Jun 12, 2011 6:59 pm
Paul
You could try this...
with the added advantage of lightened flywheel..
John :wink:
efi flywheel.jpg and
PostPost by: bob_rich » Sun Jun 12, 2011 7:09 pm
Hi Paul
I had a Ford 36 pulse wheel fitted to the crank pulley and will be mounting the sensor broadly speaking in the position shown. After installation will cut of a tooth for the reference position of around 90 degrees BTDC on cylinder 1.
hope this helps best of luck
Bob
bob_rich
PostPost by: bob_rich » Sun Jun 12, 2011 7:11 pm
Hi Paul
hope this helps best of luck (oops 4 got picture sorry !)
Bob
DSCF1020.JPG and
bob_rich
PostPost by: memini55 » Mon Jun 13, 2011 12:43 am
Paul,
I bought a lower pulley from QED and they also have the bracket for the pickup which bolts to the lower front pan and comes with spacers for the bolt up. I am using a Megasquirt and ground off a tooth on the pulley for the missing tooth.
memini55
PostPost by: bcmc33 » Tue Jun 14, 2011 11:21 am
Paul,
QED do a nice trigger crank pulley. http://qedmotorsport.co.uk/qed-shop/lot ... y-36-teeth
You need to remove a tooth in the location that suits where you put the sensor. This is mine--
Toothed Pulley position.JPG and
Toothed Pulley.JPG and
QED also supply a sensor bracket, but I made mine to suit a 2 point fixing.
Toothed Pulley position2.JPG and
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: pauljones » Fri Jun 17, 2011 3:50 pm
Not sure if ill be allowed a light weight flywheel till xmas,but its a thought.Ill have a look at the other offerings but unless this rains stops then I wont be doing a thing.I can see another weekend being lost out to the weather.
:( :( :( :cry: :cry: :cry:
pauljones
