Spyder 2.25" spring spec
Thu May 12, 2011 5:37 pm
Dear All
Just a quickie,as the subject line says,does anyone know? (coils,poundage etc)
P.S. for a Plus2-rear
Re: Spyder 2.25" spring spec
Thu May 12, 2011 6:07 pm
by oldelanman
Hi John,
According to the brochure on their website the springs are available in a wide variety of spring rates - you probably need to talk to them direct
http://www.spydercars.com/pg6_spy_2_25_rear_spring_conv.htmRegards,
Thu May 12, 2011 6:58 pm
by Jason1
Would the rate not be the same as the standard Lotus (93 lb in)?
The manual has the standard rear +2 as:
Coils = 9.7
Wire dia = 11.02mm
Rate = 93 lb in
Free length = 40.6cm
Hope its helpful?
Jason
Fri May 13, 2011 12:18 pm
by jono
I used 110 lb x 14" free length with adjustbale Koni inserts backed off a half turn from full soft. This was on Tony Thompsons advice.
As I have not driven the car yet however I cannot say if it was a good choice
Jon
