Spyder 2.25" spring spec
Dear All
Just a quickie,as the subject line says,does anyone know? (coils,poundage etc)
P.S. for a Plus2-rear
Hi John,
According to the brochure on their website the springs are available in a wide variety of spring rates - you probably need to talk to them direct
http://www.spydercars.com/pg6_spy_2_25_rear_spring_conv.htm
S4 DHC
S4 DHC
- oldelanman
Would the rate not be the same as the standard Lotus (93 lb in)?
The manual has the standard rear +2 as:
Coils = 9.7
Wire dia = 11.02mm
Rate = 93 lb in
Free length = 40.6cm
Hope its helpful?
Jason
Coils = 9.7
Wire dia = 11.02mm
Rate = 93 lb in
Hope its helpful?
Jason
Jason1 - Coveted Fifth Gear
Users browsing this forum: ericbushby, GaryE, lotusfan and 19 guests
