4 1/2J Steel Wheels - Lotus Vs Spitfire
Thu Jan 27, 2011 7:09 pm
by Esprit2
What is the offset difference between the stock Lotus and Spitfire steel bolt-on wheels? Lotus is about +1 3/32" / +1.093" / +27.76mm. I believe the Spitfire wheel is closer to 19mm, but I don't have one to measure.
Tim Engel
Re: 4 1/2J Steel Wheels - Lotus Vs Spitfire
Thu Jan 27, 2011 7:49 pm
by ardee_selby
TIM,
http://www.triumphspitfire.com/wheels.html) gives:
FACTORY WHEEL INFO
Factory wheel sizes:
3.5 x 13 for Mk1-early Mk3,
4.5 x 13 for late Mk3 to 1978 1500,
5 x 13 for 1979-80 1500's
Factory Wheel Bolt Pattern: 3 3/4" (95.2 mm)
Factory Wheel offset: +0.88" (22mm) offset for 4.5" wheels
HIH Cheers - rd
Thu Jan 27, 2011 8:08 pm
by Esprit2
Thanks rd,
I visited that site earlier but only read the chart. I now see the specs listed further down the page.
Offset:
Spitfire (website) ....... +0.88" ..... +22.00 mm
Probably..... + 7/8" ..... +0.875" ... +22.22 mm (designed in inches)
Lotus ....... +1 3/32" ... +1.093" ... +27.78 mm
Difference ..... 7/32" ..... 0.21875" ... 5.56 mm
Both Lotus & Spitfire are positive offset (ie, center web closer to outer face of rim).
