Thor Hammer, optimum size?
Hi does anyone else use a Thor hammer (copper/leather) to loosen/tighten their wheel spinners?
One like this http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
If so can you please advise what size I should get...No 1 looks too small, number 3 looks pretty hefty....Number 2, as Goldilocks might say, could be just right.
Will need to buy from UK or USA unseen on fleabay (no longer sold in Oz) hence my question.
Robert
Robert
- robertverhey
Me too. Works just fine. Only minor problem is the hide end tends to dry out over time and loosen in the head but a couple of hours in a bucket of water and it's as good as new.
S4 DHC
S4 DHC
- oldelanman
I think I'd go for the biggest one; I could then also use it to fix all of the Electrical problems
Beware of the Illuminati
Jason1 - Coveted Fifth Gear
D.J.Pelly wrote:I think I'd go for the biggest one; I could then also use it to fix all of the Electrical problems
Do I not recall one of your previous tag lines was that "if you can't fix it with a hammer then you must have an electrical problem"? My apologies for the diversion.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771 wrote:D.J.Pelly wrote:I think I'd go for the biggest one; I could then also use it to fix all of the Electrical problems
Hit the Nail right on the Head Russ; I thought my remark had fallen on "Stony Ground"
Have a good Weekend.
mac5777 wrote:Whats a hammer?
Sarto
George W. Bush; Tony Blair, take your pick
or Hammer = "A heavy Implement for hitting the Hell out of things"; an alternative for almost every other Tool that you may have in your Toolbox
Jason, been there after spending more than I ever thought on a restore. A little hammer story---While driving my wife around, showing off my newly restored pride and joy a spinner came loose and I did not have a hammer in the car. I had to resort to a piece of wood and a rock found on the side of the road. She asked do I even have a jack? My manhood was in jeopardy. She still laughs at me in fun.
With friends and I get overly enthused about the lotus, she bring up this funny story again.
Robert, others recommend a heavy lead hammer, it has a greater impact and saves the chrome on the spinner.
Drive safe,
Sarto
Drive safe,
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
Hi Bill, I was driving about 25 mph when I felt a abnormal vibration, like a flat tire. Pulled over and the back right side spinner was finger loose just enough to cause the wheel to wobble. The spinner had loosened about 3/4 of a turn from tight. For the wheel to fall off the spinner would have had to spin off the hub, which could happen fast. The lessen is, if you feel any vibration that has just started ---Pull over. Could have been bad. Aside from beating the spinners up and chipping paint, the second reason I developed my tool was to know what torque I applied to the spinners.
To stay on subject, I have been told --- finger tight and three good blows with a lead hammer should secure your wheels.
Sarto
Sarto
36/5785
LHD
36/5785
LHD
