brake master cylinder cap..
Hi Ian,
You could try J & L Spares - they recondition Girling master cylinders so they may stock the reservoir caps. I bought my servo recon kit from them. Might be worth giving them a call.
http://www.jlspares.com/brakeparts.htm
S4 DHC
S4 DHC
- oldelanman
I was able to repair mine - I just happened to have an ordinary cap without the electrical bits - and it was quite easy to transfer these bits onto the new cap.
The question arises 'why does the cap corrode when the cylinder doesn't? (both ali I think)?
Gordon
Gordon
1972 LHD Sprint 5 Cabriolet - sold!
freddy22112211 - Second Gear
Jason1 - Coveted Fifth Gear
Thanks for that Jason but to be honest it doesnt look like mine? I v not looked in detail yet but beneath the cap is a white plastic cage which i assume contains the sender then top of cap has 2 wires going into a rubber sheath..Is that similar to yours Freddie?
Ian.
Ian.
- rocket
The cap is the same as mine (in the picture the second connection is out of sight round the corner)
Gordon
Gordon
Ian,
if I understand you correctly, yes the red bit and the cap underneath are one, and just screw off like any cap. Possibly removing the connections to turn it several times.
Gordon
Gordon
rocket wrote:My cylinder cap which has the electical connecter built in has began to corrode,not badly yet but would like to source a replacement..any suggestions?
Ian
Hello All,
Did anyone ever manage to source a replacement, please?
Many thanks,
Tony
1969 Elan FHC S4 SE
- tonycharente
