are the steering rods ball joint adjustable?
Mon Mar 22, 2010 11:23 am
by phatmendus
Hi all,
can anyone tell me whether the joint inside the gaitors at each end of the steering rods are adjustable? i have my MOT coming up and i notice some play in one, but I was hoping I would be able to tighten it up rather that having to take it apart andf get a new one. Can anyone help me out with this.
thanks
Simon
Re: are the steering rods ball joint adjustable?
Mon Mar 22, 2010 12:07 pm
by GrUmPyBoDgEr
Hi Simon,
bad news I'm afraid, you'll need to buy new ones, there's no method of adjustment.
P.S. I'm interested in your Forum name "Phatmendus"
What's behind it?
Mon Mar 22, 2010 12:21 pm
by phatmendus
dam, that is bad news. do i need to buy the whole steering rack assembly, or can i get parts only?
re. forum name... I used the start of a very old email address I had from college days,In hindsight maybe i shouldnt have! (Im pretty sure im not overweight either!)
Simon
Mon Mar 22, 2010 12:50 pm
by oldelanman
Hi Simon,
If you are talking about the ball joints inside the gaiters at the ends of the steering rack itself these are shimmed and can be adjusted. But you will need to take the rack off the car to do it. I think John is talking about the track rod end ball joints which connect to the steering arms. They are not adjustable but they are easily replaced.
Mon Mar 22, 2010 1:03 pm
by gerrym
Simon, look at the Moss website for the exploded parts drawing which shows the shims, locknuts etc for the inner ball joint. With the rack horizontal in your vice (carefully mounted) You need to hang a weight on the end of the tie-rod: this determines if the ball joint is adequately loaded, i.e.it is stiff enough. Note, I'll dig out a copy of the procedure somewhere from my archives. While your at it, you should check out the rack teeth for wear. You could even check the pinion pre-load.
Gerry
Mon Mar 22, 2010 1:05 pm
by GrUmPyBoDgEr
oldelanman wrote:Hi Simon,
Yup another case of crossed lines I'm afraid.
Should have gone to Specsavers
Mon Mar 22, 2010 2:26 pm
by phatmendus
thanks for the info. ill have to get under the car and take the rack off and go from there
Simon
