Hi All,
Bob...
Thanks very much. That tool certainly looks very good and if I were competing with the Elan it is something I would buy without hesitation. BUT.. I only want to use it once and probably will have the car checked by a commercial company specializing in alignment. I think I will just set up the string lines. I am busy making up some adjustable string 'mounts' which will attach to my ramp and allow fine adjustment of the lines. It is so cold here just now I have twice went out to 'start' and ended up back inside with the kettle on. !!
My Z4 is sitting below the Elan and I don't want to take it out of the garage in case I have difficulty getting it back in. Last time I took it out to lower the Elan down it snowed quite heavily and soaked the Z.. Soft tops and snow eh!! I have loads of time so it can wait.
Hi John,
Thanks also for your input and I agree the laser is a good option that I might just utilise.
The system I have for leveling machinery (V accurate!) on one side would be spot on and easy to set up. The other laser device I have is for checking alignment through wood moulding machinery but only has a mag' base so I need to make 'something' to hold it etc. So all in all I think again I will 'box' the car in with string lines and measure. As I say it is only for basic set up, and depending on how that goes, I will decide if required to have it checked.
Brrrr!! Awaiting milder weather.
Alex B....
