Re: Front hub bearing failure
Posted: Tue Sep 29, 2009 9:06 pm
JimWol wrote:Just found this Loctite 640 http://www.scparts.co.uk/index/lang-2/l ... 343250.htm (!0ml bottle @ ?21.08) It may be worth trying.
Thanks!
Paddy
https://lotuselan.net/forums/
paddy wrote:I've already got a bottle of 638 (previously used on my rears) which is nearly as good but its effectiveness tails off after 150C but I think I might just go for that.
Paddy
69S4 wrote:Do you really need something with a high temperature spec? I presume you're using something like Castrol LM to lube the bearing and Castrol say 120C max for that. If the bearing is getting that hot you're much more likely to have a problem with the lubricant failing than the loctite.
