Girling brake servo - where's the little ball bearing gone?
Sat Jun 20, 2009 5:59 pm
by alaric
Hi all. I've been trying to free up my Girling 2B brake servo, and with it now in pieces I can't find the little ball bearing that's part of the input piston. I've looked everywhere in the garage and outside. It's just gone. I don't recall seeing it when it came apart. Does anyone know what size it is? I think it's a non return valve between the high pressure and low pressure sides of the servo, so it's pretty important.
Any suggestions on where to buy a replacement servo would be appreciated.
All the best.
Sean.
Re: Girling brake servo - where's the little ball bearing gone?
Sun Jun 21, 2009 5:33 pm
by mark030358
Cant answer you bb question, but did u cut the band off on the vac tank to split it?? Also where did u get the rebuild kit from??
Sun Jun 21, 2009 5:47 pm
Mark, I did both the Europa and the Sprint, I'did'nt cut the band as you can with a bit of time and effort remove and replace the original band.
Sun Jun 21, 2009 7:23 pm
by oldelanman
I got my kit from J & L Spares. The kit included the ball you are missing together with all the seals and gaskets and a new clamping band. They were also able to supply replacement (used) air valves as one of mine was broken and these are not part of the kit. Not cheap though ... the kit was ?125 a year ago but if I recall correctly exchange rebuilt units were around double that at the time.
01706 644201
http://www.jlspares.comHope this helps. Regards,
Sun Jun 21, 2009 7:26 pm
by alaric
Thanks Roger that's really helpful. I'll get in touch and see what they can supply and for how much - I have a band with the nut and bolt in so it can be put back on again.
All the best.
Sean.
Sun Jun 21, 2009 7:45 pm
by oldelanman
Hi Sean,
If you don't have any joy with J & L Spares I've just dug out details of another supplier who might help.......PowerTrack Ltd.
01753 842680
[email protected]All the best.
Sun Jun 21, 2009 10:08 pm
by mark030358
Brian,
How did you remove the band? it seems crimped on to me
Mon Jun 22, 2009 12:12 am
Mark, Its several years ago that I did it but from memory I uncrimped the indentations with a screwdriver to loosen the band off then rotated the band enough to pass the segments until I got the two halfs apart, it is a bit of a pain but it can be done
elan-f15/girling-mk2b-servo-t1486.html
