Removing Rer Strut (should I Be Brutal?)
Tim,
I just went through same: took apart original Armstrong struts. The hard part was removing the threaded aluminum top cap - due to the staking of the strut tube. Once the cap was off, all of the innards literally fell out. There is no additional device (nuts, set screws, etc.) holding the struts inner workings in and they are not a tight fit. No force was required, only turning the tube upside down.
I assume that you had a fair amount of shock fluid pour all over the place. The stuff smells like gear oil; kind of a sulphur smell. If you did not have this fluid spilling out, then you might have a rust problem. The "guts" may be rusted in place. It is not hard to immagine this scenario.
Whatever the case, I would go ahead and get brutal if needed. This is assuming that you are replacing the original Armstrong units with Spax, Koni, AVO, or some other new shock. Such shocks are self-contained inserts. New inserts do not require a smooth internal surface, only intact threads at the top of the strut tube.
richboyd - Third Gear
There is a small set screw on the side of my strut tube that holds the shock. Sorry no pictures are drawings to help locate the screw.
Unibrain - Third Gear
