Steering Impact Clamp
Posted: Sat Mar 26, 2005 9:30 am
Hello Everyone,
I have just returned from a brilliant days drive in my fathers S4 FHC, which he happily lends to me. He is a fine man.
We are having a problem where the inner and outer steering shafts slide towards each other till the base of the steeringwheel touches the outer column (and just for a laugh the hornpush popped out last weekend when I went to toot another Lotus driver).
I am siding the lower shaft as far down as possible, sitting the top shaft so there is about a 10mm gap between the base of the steering wheel boss. I then tighten the clamp bolts as tight as possible, followed by tightening the grub screw and locknut as tight as possible.
This holds the shafts in place for about 3 hours driving before the top shaft starts to slide down.
Am I doing something wrong? If not is there a better sort of clamp to use?
Steve.
Steve.
