Torque Setting
The caliper is from Lee Chapman Racing. It is not drilled for attachment of the handbrake, but it could be. You can find it at
http://www.leechapmanracing.com
Jerry
Jerry
- jkolb
Provided you have around 5 threads minimum in the aluminium and its a good quality aluminium alloy you should be able to use the same torque setting as for the iron hub. However I would talk to the manufacturer about what they recommend. If you had room for a backup nut behind the alloy casting on the bolt I would probably add that so not relying on the alloy threads.
