Rear Upright Bearings Elan +2
Hi! not totally sure,but i think inner rear wheel bearing was same as escort mk1 and2 rear,without the retaining collar.outer bearing is the same as diff output shaft bearing,i think a 6206 type,will confirm part numbers in next few days, cheers
martin
martin
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
- lotusanglia1965
Outer bearings are SKF 6206-2RS or equivalent, the most common bearing in the world I think and available everywhere from any bearing supplier
Inner bearings are a little harder to find. They used to be in SKF kit 2737 in Australia which was the pair of rear axle bearings for a range of cars and included spacers that you did not use. Last time I bought some, my usual SKF supplier could could not supply the kit and ordered in bearings for me from FBJ part number 411546R.
The inner bearings have following dimensions if trying to track down
OD 62.00 mm
ID 29.96 mm
width of outer race 21.00 mm
width of inner race 23.95 mm
with rubber seals both sides
regards
OD 62.00 mm
ID 29.96 mm
regards
