fuel line connectors 1/2 inch - 18 thread
I wanted to connect a fuel pressure gauge to my elan fuel pump, but the fuel gauge connector has a different thread density.
The fuel pump connector is 1/2 inch 18 thread pitch I believe. The pressure gauge seems to be 20 pitch.
Car parts shops do not seem to have 1/2-18 fuel connectors. Anyone able to suggest a converter/adaptor?
Paul
Paul
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
pcarew - Second Gear
Paul
Try your local plumbing store or one of the specialist tuning outfits like Dave Bean or RD both on your side of the water
Tony
Tony
- tonyabacus
Paul
I was thinking a little more about your connector, it is likely to be a British Standard Pipe thread or depending whether it is the standard pump or an electric pump could be a Metric thread. So can you confirm what sort of pump you have and who made the gauge(British or other). Also do you need a connector with external threads at both ends or internal or a combination?
Tony
Tony
- tonyabacus
What fuel pump do you have ? The original AC glass bowl pump has 1/2"-20 UNF threads.
viewtopic.php?f=40&t=42686&start=
S4 DHC
S4 DHC
- oldelanman
I figure it’s gonna be a bit tough to find the exact one you’re looking for.
Easier might be to return the gauge, or go to a giant auto parts place for the fitting. But I fear you barking up a the wrong tree, as most are for domestic autos within the last 10 years. Specialty fitting place, or try Spruce Aircraft or McMaster Carr.
Sunpro should have it, this isn’t what you need but it might start the hunt.
https://www.amazon.ae/Sunpro-CP7573-Met ... B00029JXLG
Love your Mother
Earth
Love your Mother
Earth
- Location: RACECAR spelled backward, is——RACECAR! Kayak, Kayak. The Faster You Drive...The Slower You Age
What I do, alt least with plumbing, is bring the parts to the store and ask, "I want to connect this to that" With the big box stores, at least you can try different fittings to see what fits so you are no longer guessing. I understand you may not want to take about the fuel system of your Elan.
Fred Talmadge - Third Gear
If you want a pressure gauge to check what the carbs are getting, you should fit it at carb height ideally. I have a gauge with a T piece and two short lengths of fuel hose. When I want to check the pressure, I just undo the hose between the two carbs, and fit it temporarily between the two, I keep the gauge with t piece in the spares box in the back of the car.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
Hello and thanks all for your thoughts,
The car has a replacement fuel pump, but I happen to have the original AC (Glass Bowl) pump that I've just refurbished that I want to retro fit.
Both pumps (the current and the original) have 1/2 inch- 18 threads (I measured and counted the threads).
The reason for all of this shenanigans is that I've been having a weber flooding issue and the fuel pump might be part of the problem with it's fuel pressure, hence the wish to measure it and the desire to replace with the refurbished original.
Putting a 'tee' in the fuel line was a good idea, but my fuel line is steel braid and it doesn't look very easy to inset a Tee into it.
Paul
Paul
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
Bolt in through a banjo fitting.
Yes, there are fitting for banjo to gauge.
What height is your fue at in carbs. Easy to measure off the car.
Love your Mother
Earth
Love your Mother
Earth
I re-measured and now I think I may have made a mistake,
I'm now thinking that maybe the Fuel Pump thread is actually 1/2-20
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
Elan3 has the right idea.
But you say you have a steel braided pipe. Substitute this with a length of rubber pipe.
1. Purchase a four way brass fitting with the correct thread to take the gauge and three hose outlets.
2. Next purchase some rubber fuel pipe of the correct diameter,
3. Cut the pipe to the length between the two carbs less the width of the "T" piece
4. Join the pipebetween the "T" piece and the carbs and clamp them up
5. Join the remainig pipe on the four way with the fuel pump (you may need a straight brass fitting with a thread to match the pump and a hose outlet pipe
6. Clamp up the fuel pump end
That is all you need, so now you can start up and check the pressure, but check at idle and with an open throttle to verify it is not over or under pumping
Tony
Tony
- tonyabacus
Ok, I can definitively say I made a measurement mistake. The Fuel Pump is definitively 1/2inch-20 UNC.
I just ran out to the local parts store with the fuel pump in hand
I now have a 1/2inch-20 thread to barb fitting that I think I can attach via hose to the gauge.
and verified the thread.Fred Talmadge wrote: (A nod to Freds suggestion)
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
tonyabacus wrote:Elan3 has the right idea.
Tony
Thanks Tony, if the barb to hose fitting doesn't work, I'll go down this path
Paul
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
