best location for electric fuel pump
In response to Alan and 2cams70, you are of course both correct.
In the case of the standard Elan, whether by design or by luck, the fuel pump is mounted under the carbs, which is about as good a place to have it as possible to minimise this effect.
I think I made the point that this effect was unlikely to be noticeable in a road car - the E Type has its fuel pump in the boot, and that doesn't seem to have held it back too badly.
For a competition car, there may be some merit in considering this problem. As I mentioned earlier in the thread, one contributor mentioned that there was a measurable change in fuel pressure at the carbs during braking and acceleration.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I completely agree that acceleration/deceleration can change the pressure at the discharge end of the fuel line, depending on the length of the line, but the line is not discharging through a constant orifice, but through the open/closed position of the float valve. This would significantly remove the influence of any acceleration effect.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
'That's harsh from someone who keeps his Sprint in one!'
Harsh. If giving 'sage' advise on keeping a car original is harsh, I shall continue to do so.
Someone mentioned on here a while ago that you can no longer express a personal opinion on here without the Woke Police poking their noses in, this being a case in point.
I must have missed where 'commentators' asked the OP why he wants to change to an electric pump? Why not deal with any problem that might exist, and keep the car as close to original as possible, before resorting to fitting an electric pump. I would think that 95% of old Lotus still run mechanical fuel pumps, from what I see at shows. They are incredibly reliable.
Leslie
Leslie
- 512BB
Think of it as being like an enlarged prostate. The main thing with something 50+ years old is to make sure the lines are clear. This is more important than the pump itself. If the original pump still works don’t tamper with it and consider it as something to cherish as an optional extra.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Leslie,
My stance on originality is well documented and it was the manner of your delivery of sagicity to an inexperienced member that prompted my ironic response. I endorse your message to not fit an electric pump without good reason.
I fitted one a few years ago as I believed the sudden onset of fuel vapourisation was due to alcohol in the petrol. Nobody else reported it so, as I had already driven 200,000 miles without one, I switched it off and am searching for other causes.
Meg
