S4 No Fuel
• Page 1 of 4 • 1, 2, 3, 4
With the engine cranking over now I am faced with a new problem.
With starter fluid, the engine lights and runs great. As soon as the starter fluid burns out the engine stops.
I have rebuild both carbs and the fuel pump - new gaskets, seals, diaphragm, and a complete tear down and cleaning of all passages. New diaphragm and valves in the fuel pump.
I pulled the front carb and the bowl is full of fuel. The float valve opens and closes as it should and float level set per the manual.
Idle trim screws are fully closed.
The carb pistons are moving up and down during cranking. No oil in the dash pots yet.
I have tried with and without choke.
Engine is original configuration with active crossover pipes and secondary butterflies.
Any other ideas before I pull the carbs back off and tear them down?
- Temmck
"The carb pistons are moving up and down during cranking. No oil in the dash pots yet."
You need to add oil to the dashpots as these act as a damper to the pistons. Without oil you are likely to be pulling little ( if any) fuel through the carb..
Brian.
Brian.
- ncm
If the bowl is full of fuel, then it is getting that far... the only fuel path from there to the engine is the jet and manifold. The only thing that should impede the jet flow is the needle. New jets and/or needles?
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Can you blow some compressed air from the tank filler, have an assistant crank or at least look
Love your Mother
Earth
Love your Mother
Earth
Ok, so fuel is getting to the bowl and you have the same jets and needles as previous... the other variable is the air flow to pull the fuel through the jet... is the vacuum port on the manifold connected to the front chassis section or lights (or, better yet for this purpose, just plugged)?
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Grab a picture of your overall setup to post, too. It struck me I made an assumption you have Strombergs based on various other comments, not because you said so. Seeing your carbs, how they are mounted, etc. might spark more ideas.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Sorry! Yes, this car is fitter with Strombergs.
Fuel is new.
I plugged the vacuum lines in the front and rear of the intake manifold - No joy.
Squirted a little fuel in the carb and engine jumped to life...briefly.
I have attempted to add a picture. I hope it comes through, seems necessarily complicated.
Fuel is new.
- Temmck
Missing nut .. possible source of air leak ?
S4 DHC
S4 DHC
- oldelanman
Users browsing this forum: gherlt and 5 guests
