Carb synchrometer mods to fit?
The synch tool I use on downdraft Webers will not fit between the sidedraft carbs and the body in my Elan. I'm off to the hardware store for some tubing to modify, but I wanted to check to see if anyone has the "MacGyver plan" already thought out.
Thank you,
Joe
Thank you,
Joe
- elaninfuture
elaninfuture wrote:The synch tool I use on downdraft Webers will not fit between the sidedraft carbs and the body in my Elan.
To give you some solution it would be necessary to know which synchrometer make/model you have now.
At least a picture....
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
As above, i use the Sk Synchrometer but i have to use an elbow attachment to use it on the +2
https://www.ebay.co.uk/itm/294353448890 ... SwB-1YnbeE
I've tried a few different sync tools and the SK works best for me, the main thing i like is it doesn't cause too much of a vacuum in the inlet/carb causing it to flood that cylinder like some i have used in the past.
Grizzly - Coveted Fifth Gear
Thanks guys. I also use the SK as above. Mine wouldn't fit on the throat nearest the front of the car, but I've done a mod to make the tool shorter. Works now. Thanks.
- elaninfuture
Hello chaps, I also use a sk meter and last year bought the elbow ( about £28) much easier to use,should have bought it years ago.Steve
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
