Remove Stromberg Carbs
Assistance please. I am either being very stupid or its difficult. I assume both carbs have to be removed together, if this is correct how do you get at the 2 nuts on the bottom of the rear carb. I can see them but getting a spanner on them is proving difficult.
Thanks for any help
Thanks for any help
- TOR15T
2 nuts? I have one nut there (and that's enough trouble to get off / replace). You need a short 1/2" ring spanner (with a piece of string attached to stop it falling into the depths - you'll drop it a lot) and multijointed fingers.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
There is only one, but is a pita to get to. I finally cut a slot underneath a reach it through the footwell from inside. When finished, I slide some black duct tape under the carb and also put a layer from the inside. I guess water could get in there, but there are many other places as well.
Bob
Bob
Bob Bulfin
1969 Elan S4 DHC
Mobile, AL USA
1969 Elan S4 DHC
Mobile, AL USA
- bulfin
My car is a Federal Sprint, so likely a bit different than yours. There are 3 nuts holding an intermediate plate to the Federal crossover casting. There is no way I've found to get at the bottom nut of the rear carb (yes, without cutting a hole in the footwell).
The alternative is to remove the 4 nuts holding the carb to the intermediate plate. On a Federal Sprint this is doable, but I had to take a 1/2" combination wrench, cut the closed end off to shorten it, and grind it thinner to get at the nuts.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
You may be able to get at the nuts by removing the engine mount bolts and easing the engine up slightly to get a socket and extension on. Keep a check on the hoses, wires and oil pressure gauge line and disconnect battery.
- tonyabacus
Probably doesn't apply here but on my +2 with webbers I use a small bit racket + socket reaching under the airbox from the front to get the lower rear nuts. Tricky to get on, but once you get it on you can normally get them off quickly.
Specifically this tool set:
https://www.lowes.com/pd/Kobalt-35-Piec ... et/3387640
- mbell
steve lyle wrote:My car is a Federal Sprint, so likely a bit different than yours. There are 3 nuts holding an intermediate plate to the Federal crossover casting. There is no way I've found to get at the bottom nut of the rear carb (yes, without cutting a hole in the footwell).
You have to remove the intermediate plate from the secondary throttle body ... extract the carbs then remove the carbs from the intermediate plates.
hope this helps
Jaman
1969 S4 Fed Sprint Stromberg
- jaman
