Fuel sender, resistance range
PostPost by: 1963 S1 » Thu Apr 29, 2021 9:15 pm
I would like to know what the expected ohms resistance range should be for a 1963 Series 1 Elan Smith's fuel sender. Ohms reading at full vs. empty. The Smiths sender which is currently installed is model number: FT 3334 / 50. The fuel gauge is Smiths FG 2530 / 71. Thank you.
IMG_0960e.jpg and
IMG_0963.JPG and
1963 S1
PostPost by: gherlt » Fri Apr 30, 2021 5:13 am
1964 S1 (in boxes)
1967 S3 DHC
1969 S4 FHC
gherlt
PostPost by: reds4se » Fri Apr 30, 2021 9:17 am
I found the same sender installed in my S4 tank and the range was from 3 ohms empty to 83 ohms full.
reds4se
First Gear
First Gear
PostPost by: Billmack » Sat May 01, 2021 1:38 pm
If the S1 and S4 have the same sender one of them is likely wrong. Info about this is on this forum somewhere. I saw it recently.
Billmack
PostPost by: Quart Meg Miles » Fri May 07, 2021 11:09 pm
Late to the party! The FT sender is the correct one for a S1/S2 Elan and nominally is 0 Ohms in empty position and 87 Ohms at full.
I measured my original one, 30 years ago when I fitted a new tank with the later, wrong, sender, and it was less than 5 Ohms empty and between 75 and 80 Ohms at full. My gauge is type FG.
A thread started by nomad "Fuel Gauges ??" 14/01/2015 includes a description by rviani, according to my notes.
Meg
Quart Meg Miles
PostPost by: 1963 S1 » Thu May 20, 2021 11:40 pm
Thank you everyone for your inputs. Very helpful. I tested my FT sender; it registered ~3 Ohms empty and ~87 Ohms full. And accurately, the gauge followed the spectrum of the sender. Now to reinstall the sender so it doesn't become the source of a fuel leak...
1963 S1
PostPost by: jk952 » Tue Jun 08, 2021 12:28 pm
“ Now to reinstall the sender so it doesn't become the source of a fuel leak...”
as well advised by others…use Hylomar :)
jk952
PostPost by: 1963 S1 » Tue Jun 08, 2021 7:59 pm
Thanks for the tip. I opted for Permatex H3 Aviation Sealant. So far there seems to be no leaks!
1963 S1
