Webers pick up from cold
Tue Nov 24, 2020 3:15 pm
by checkrail
Hi, Starting my +2 from cold I give it 2/3 pumps and it always starts 1st turn of the key, the problem is however careful I am with the throttle it will not keep running, it usually takes 3 goes on the starter before I can gently increase the revs and then it's fine.
I am on a normal mechanical fuel pump and no choke fitted, it will idle at approx 600 rpm stone cold and 900 when hot.
Any suggestions would be very welcome Thanks John
Re: Webers pick up from cold
Tue Nov 24, 2020 3:37 pm
by alanr
Mine would do exactly the same thing if I didn't use the choke to keep it running when stone cold.
I do exactly the same as you, also mechanical pump, and it starts immediately after a couple of accelerator pumps but then I use the choke to keep it running for a couple of minutes until it revs cleanly then push the choke in.
Suggest you reconnect the choke.
Alan.
Tue Nov 24, 2020 5:52 pm
by bitsobrits
checkrail wrote:Hi, Starting my +2 from cold I give it 2/3 pumps and it always starts 1st turn of the key, the problem is however careful I am with the throttle it will not keep running, it usually takes 3 goes on the starter before I can gently increase the revs and then it's fine.
Seems to me normal operation for a carbureted car when not using the choke.
We have become so spoiled by modern fuel injected machines.....
Tue Nov 24, 2020 6:46 pm
by elans3
[/quote]Seems to me normal operation for a carbureted car when not using the choke.
We have become so spoiled by modern fuel injected machines.....[/quote]
Not normal for either of my Weber carburettored Twincams, (an S3 Elan and an Alfa 105 2 litre).
My Elan on 40 DCOE31's starts immediately on 2 pumps, and after 4/5 seconds of "tickling" will rev cleanly and idle at about 600 rpm after 10 seconds. When the thermostat opens the idle increases to 850 / 900 rpm.
The only mod to the Elan is an Aldon Ignitor (Pertronix) & has standard mechanical fuel pump.
The Alfa has a 123 distributor and an electric fuel pump.
I never have the choke cable connected on either, nor have I ever connected a DCOE choke cable in 45 years of having them on a myriad of different cars.
Sounds like you may have a slight air ingress leak somewhere, or might be a fine tune / balance issue.
Wed Nov 25, 2020 4:47 pm
by checkrail
Thanks for all the replies, but I don't have a choke cable fitted. When I bought the car the cable was badly frayed and not usable.
If it's left longer than about three days I have the problem.
Wed Nov 25, 2020 5:21 pm
by richardcox_lotus
Mine has always behaved the same if the carb chambers have been emptied. I ponder if it’s a result of the mechanical pump struggling at low revs to fill the chambers fast enough for it to be sucked through the cylinders in a low vacuum environment.
Just an opinion - no facts or science behind it !
Regard
Richard
Wed Nov 25, 2020 6:03 pm
by MrBonus
I always enjoy reading these threads to see if my car is "normal" or not. My Elan is/was my first carb'd car.
I have an electric pump which I let prime for 10 - 15 seconds, then 2-4 pumps if it's warm outside and 6 - 8 if it's cold. No choke. It usually starts on the first turn but does require a little throttle assistance to idle for the first 10 or so seconds, then it will hold a roughish 600 RPM idle until the engine warms up, then it's fine.
Fri Nov 27, 2020 7:20 am
by webbslinger
MrBonus pretty much described how my car starts, although mine usually takes a few less pumps. The last time I used the choke was in 1989, just before I bought a new set of plugs. The choke knob got a free ride for 30 years until it was replaced last year with a battery kill switch. I hope the switch is as unneeded as the choke was.
