replacement electric fuel pump
Hi all, I have replaced my mechanical fuel pump with and electric one and mounted it on the pedal box. It was one I had hanging around as a spare for my previous car which had a temperamental SU pump. Its a cheap and cheerful Chinese thing which functions fine but it is very noisy and I can't live with it. It makes a loud ticking/clacking noise which would probably be ok if it were rear mounted, but not where it is in the engine bay.
Does anyone have any suggestions or recommendations for a reasonably quiet and fairly compact pump? It would also need to be fairly low pressure, the one I have is 3-5 psi which seems to be about right for the Strombergs.
An SU size/style pump would be more difficult to fit in the space I've got. There are plenty of pumps which would appear to do the job, but until its installed I wouldn't know if its quieter or not - grateful for any advice. Thanks.
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
- Andy Hamblin
Hi Andy,
lots on here use the Huco, its quiet and doesnt need a pressure regulator...
https://www.dellorto.co.uk/shop/car-accessories/fuel-pumps-regulators-accessories/fuel-pumps-carburettor/huco-low-pressure-12v-fuel-pump-133010/
Useful info here!
https://lotuselan.net/forums/viewtopic.php?f=31&t=46315
Iain
Useful info here!
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Hi Andy
Have a look at Hardi pumps https://www.hardi-automotive.com/en/pro ... uel-pumps/
I replaced the SU pump in an MGA with one and it really is very quiet. If you could physically fit it in your +2 you won't be disappointed with the noise. They are viewed as one of the more reliable pumps around.
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
I am thinking about a 60304 FACET POSI-FLO for my car when I get around to reworking the fuel system.
I have weber carbs so prefer lower (1-2PSI) pressure pump. Currently have one like:
https://www.amazon.com/gp/product/B00496RE82
Mounted near pedal box area. I measured it at 3.5PSI. This seem to be the pump offered by Rdent. It is very audible with engine off but I don't notice it with engine running.
- mbell
many thanks gents. All good suggestions that I will check out.
Andy
Andy
- Andy Hamblin
I use a Redline low pressure fuel pump. Very compact, pretty quiet, more so if on a soft mount. Does better as a pusher than puller however, so mine is mounted in the trunk.
http://www.redlineweber.com/SEMA2002/ht ... _pumps.htm
elangtv2000 - Third Gear
elangtv2000 wrote:I use a Redline low pressure fuel pump. Very compact, pretty quiet, more so if on a soft mount. Does better as a pusher than puller however, so mine is mounted in the trunk.
Electric pumps don't like taking suction lift prime very well, so mounting them back at the tank is best practice.
StressCraxx wrote:elangtv2000 wrote:I use a Redline low pressure fuel pump. Very compact, pretty quiet, more so if on a soft mount. Does better as a pusher than puller however, so mine is mounted in the trunk.
based on the advice of others on the forum, I have ordered the Huco:
https://www.dellorto.co.uk/shop/car-acc ... mp-133010/
It says: "This pump is a suction type and designed to be fitted in the engine bay of the vehicle." so I'm hoping it will be ok.
Thanks for all the advice and recommendations.
- Andy Hamblin
It was common practice to mount an SU pump in the engine compartment on T series MGs. Apparently the introduction of higher octane fuel caused vapour locks which were avoided by rear mounting the pump. Interesting to note that the standard pump on the Elan is engine mounted and therefore a 'sucker' rather than a 'blower', and its not clear to me why that would behave any differently to an electric pump.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Mechanical pumps use a diaphragm which pulls a suction without relying on the liquid itself to seal to rotors, vanes, or pistons.
Think of a vacuum bulb gas siphon vs. a pump. If you use the vacuum bulb and hose, you will suck the fuel up above the static level of the tank, until it flows by siphon effect. Try to hook up a rotary or piston pump to a hose and drop the hose in the tank and the pump will spin but not be able to create a suction.
elangtv2000 wrote:Mechanical pumps use a diaphragm which pulls a suction without relying on the liquid itself to seal to rotors, vanes, or pistons.
Your point is well taken, but SU electric pumps use a diaphragm - so in principle would be exactly the same as the engine mounted pump.
https://mgaguru.com/mgtech/fuel/fuel.htm
Your response would also suggest that other electric fuel pumps need to be mounted below the level of the fuel in the tank as they don't self prime. The two Facet pumps I have in the Elan I race are both mounted above the level of the tanks, and manage to operate just fine.
32 Standard 12
32 Standard 12
- Andy8421
Good point. I wasn't trying to be exhaustive describing all pump technologies. As the SU is a diaphragm pump, it does fit my statement about being able to pull a suction, and why some electric diaphragm pumps can be mounted in the engine bay, while some rotary or piston pumps need to be below the fuel level.
Regarding rotary or piston pumps, I wasn't trying to imply absolute characteristics, and it should be noted that the various types of electric pumps have different dry lift capabilities. The Facet round pump is stated to have more than double the dry lift capacity of the cube pump, but also may require a regulator as a result of the additional pressure.
https://www.merlinmotorsport.co.uk/know ... ettors-282
The OP has apparently found a pump that has sufficient dry lift capacity to be mounted up front, which seems to be the result of design details.
Regarding placement, my own preference is for the boot, because I don't want to jam more stuff and wiring into the engine bay, and to perhaps prolong the life of the pump by reducing temperatures. Regarding noise of the Redline Weber pump, I found using the included strap mount allows the pump to transmit more noise, but using a soft rubber standoff really reduces the noise. With the motor running, it's not audible either way in my S3.
This may interest some...
https://www.onallcylinders.com/2017/01/ ... p-designs/
