Stromberg throttle cable
Tue May 26, 2020 5:32 pm
by lotusbc
I have an S4 with Strombergs that the po installed, they are the high balance pipe type. My question is how to secure the throttle cable at the carb end. The po had clamped a small bracket to the balance pipe with hose clamps. I'd like to do something better that looks 'right' . In the attached photo you can get an idea what I'm trying to improve.
Re: Stromberg throttle cable
Tue May 26, 2020 6:13 pm
by 69S4
It’s because you don’t have the Stromberg version cam cover. That one has a flat area machined about half way down the inlet side where the cable outer is located. The inner then continues down to the throttle spindle.
Tue May 26, 2020 10:45 pm
by Evante
Here is an elegant solution.
by Evante
One more.
Wed May 27, 2020 5:13 pm
by velo5338
Here's the solution with the proper Stromberg cam cover.
Thu May 28, 2020 11:31 am
by RogerFrench
Evante wrote:One more.
These are the high-specification Strombergs.
Thu May 28, 2020 11:43 am
by 661
Thu May 28, 2020 1:49 pm
by lotusbc
The original plan was to drill a couple of holes and fit a simple bracket, but I'm hesitant. Is there a downside to drilling holes in the cam cover? In the correct cover are holes threaded or is the bracket affixed with bolts and nuts? The installations pictured look good. I'd have to replace the carb mounting bolts to fix anything as they are too short.
Thu May 28, 2020 1:55 pm
by 69S4
The Stromberg cover is thicker in the area where the bracket sits and the screw holes are tapped into the metal. The Weber ones are too thin to do that so it would have to be a bracket fixed to the sealing bolts - like 661's - or similar using the manifold bolts. Doesn't look that difficult to do either though.
Thu May 28, 2020 2:54 pm
by oldelanman
The threads are tapped into blind bosses cast into the cover.
A good many engines have been converted from Stromberg to Weber heads over the years .. maybe somebody has a Stromberg cam cover they would swap with your Weber one ? Try posting in the Wanted section on here.
Thu May 28, 2020 10:26 pm
by Evante
He is a throttle cable bracket that I build myself. It was a first try, and after I am done with some other fixes, I will go back and make another that looks a little more elegant. It was done with aluminum stock, aluminum weld, and a propane torch. Here is a link for low temperature aluminum welding:
https://www.youtube.com/watch?v=jtvOkI_pvMI
Fri Jan 01, 2021 5:47 am
by h20hamelan
Anyone know the source to purchase, or are they standard bike cables?
Thought they were thicker?
Sat Jan 02, 2021 3:23 am
by h20hamelan
Maybe a standard bike cable with a washer over the end
Are throttle cables on the elan not thicker?
Sat Jan 02, 2021 10:47 am
by 69S4
The inner wire on my throttle cable is 1.50mm. I doubt it's the original but its been on there for so long I can't ever remember changing it. 1.50mm is a standard size for many bicycle and motorcycle applications and you can buy the inner on its own for around £1.50/ metre (ie very cheap). Not sure who you'd get it from in the US but I've used these people in the UK a number of times when I make up motorcycle cables -
https://www.venhill.co.uk/cables-and-co ... trand.html The pedal end has a nipple soldered on it (which is slightly tricky to do if you don't have the bits) but the carb end uses a screw on type fixing. Mine looks like it was home made by a previous owner (it's secure but doesn't fit very well (so I suppose it could be Lotus!)).
Anyone have a picture of what the original Lotus Stromberg carb end cable fixing looks like?
Sat Jan 02, 2021 12:26 pm
by oldelanman
Is this what you need or do you mean the bracket on the cam cover ? I have a drawing of that if needed.
