Electric fuel pump elan +2
• Page 1 of 3 • 1, 2, 3
Where is the best place to install the fuel pump in a plus 2? I bought a Huco fuel pump and I’m looking for the best place to install in the engine bay.
Diego
Diego
- Dieschelan
And if you can find make an isolating bracket (at least some rubber between body and bracket), not only will the pump make noise, it will vibrate also.
Love your Mother
Earth
Love your Mother
Earth
I have tried three, none the Huco. They all have more vibration than I would like on the +2
Love your Mother
Earth
Love your Mother
Earth
Longer term I want to move it to the rear of the car but this is a convenient spot for access and making connections and close to where it was fired when I got the car.
- mbell
Dieschelan wrote:Can someone put some photos?
Sure:
A small note of caution. When adjusting the angle of the inlet and outlet spigots on the Huco pump, do not undo them all the way. Do not let the spigots come all the way out of the cylinders they are seated in, or the silicone O ring will come out and it's a bastard to get back in again. Unscrew the screw, then hold the spigot down while rotating to the required position. Yes, it will move up and down slightly as you turn it, thanks to the serrations it is mating with on the pump body. Just don't let it come out!
@mbell - that's a different pump design which I guess uses a motor and impeller, hence noisy. The Huco has a solenoid and plunger like the old electric pumps, so it's much quieter.
JonB - Coveted Fifth Gear
Has someone mounted the fuel pump near the radiator? It’s not recomended to install it near to the heat.
- Dieschelan
Regarding mounting potentially noisy pumps, Facet supplies an FPA905 pump mounting kit (see
https://www.demon-tweeks.com/us/facet-fuel-pump-rubber-mounting-kit-fsefpa905/)
that I used to mount one of their reciprocating pumps to a steel-frame car and it reduced the ticking/thumping noise to a dull thumping just audible enough that I could make out when the float bowls were filled. With the engine running it was inaudible.
It would probably have a relatively similar effect on the usually much noisier rotary pumps.
And it’s inexpensive.
- awatkins
Dieschelan wrote:Hi
Diego
Why do you want to fit it in the engine bay? Have you considered the rear of the car - use the wasted space at the back of the spare wheel where it is cooler, out of the way and quiet..?
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
I know not Lotus but on my TVR 3000S and TVR 3000M i have fitted Huco Pumps in the Boot.
Perfect job.
Perfect job.
- alan.barker
Again, the Huco is quiet even when solidly mounted. Mine's in the engine bay for convenience, and because that is where it is designed to go.
According to: https://www.dellorto.co.uk/shop/car-acc ... mp-133010/
...assuming this is the same model Diego is using.
This pump is a suction type and designed to be fitted in the engine bay of the vehicle.
Jon's correct. Put it in the boot and it is a changed into a pusher pump.
From the site -
" This pump is a suction type and designed to be fitted in the engine bay of the vehicle."
I mounted mine on a pair of fat, rubber plumbing washers to isolate. I've no idea if it made the slightest difference. Quiet tick when priming, then with the engine running ........ you jest!
From the site -
- vincereynard
