69 Stromberg bodywork clearance
I have noted contact between the bottom of the rear Stromberg carburetor and the body work. The motor mounts appear to be okay. Is this a normally close fit on these cars? In the event it is a motor mount issue has anyone been successful in replacing the exhaust side motor mount with the headers in place.
Also getting engine vibration transmitted to the body to the point that the outside mirror rattles. Not sure this is due to contact between rear carb and the bodly. The engine has just been assembled and installed after 20 years in a box. While I have not really noticed the vibration so much in the past the engine does have a lightened flywheel.
STLREDZ06
- kfbrinton
There's two components to the bodywork clearance issue - firstly do you have the correct carb side mount and, secondly, is it any good if you do. The Stromberg engine uses the same engine mount on both sides whereas the other versions use a different one on the carb side. From memory the correct mount lowers that side of the engine to stop the carb tops hitting the bonnet / hood. And that, of course, results in the carb bottoms hitting the footwell.
I tried a number of mount changes and couldn't find one that stopped the carbs hitting something. In the end I gave up and slotted the engine mount holes on the chassis side. That way I could raise or lower the engine mm by mm until it stopped hitting. Making sure the bonnet mounting bolts at the front were correctly set up and likewise with the catches at the rear gave the bonnet a bit more clearance.
Re the vibration - mine has a lightened flywheel and I don't get mirror shake. Carb balance is tough with the Strombergs - it's hard to get an even idle. Maybe it's that.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Share a few pics of the mounts and the carb mounting and we might have some better ideas for you, but the base of the carbs should have good clearance at the bottom if all is set up correctly. I had the same problem as you as a result of a failing motor mount - replacing them gave me the expected clearance. I did the replacement with the headers on so it can be done - but fiddly and I sure wish I had smaller hands when I did!
If the motor mounts are, in fact, good, I'd next wonder if you installed the carbs without the adaptor - the extra extension from the engine would give the carbs a little more lift.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
There are two engine mount types as far as I am aware
standard - i believe from an Anglia
high lift - a Lotus special
The Weber elan used a high lift mount on the carb side and standard on the exhaust side to achieve clearance at the bottom of the Weber ( and Delortos ) to the foot well. The engine was not level and was raised on the carb side
The Stromberg Elan used two standard mounts as Strombergs did not need to be lifted for clearance with the foot well and the engine was horizontal
The Plus 2 foot well provided greater clearance and used the standard mount on both sides in both the Weber and Stromberg versions.
If you have Strombergs hitting the foot well in an Elan then the engine mounts may have failed ( probable as current engine mounts are poor quality and can fail in a few weeks). Perhaps you have a Lotus high lift mount on the exhaust and standard on the inlet which would tilt the engine the other way and may cause the Stromberg to hit. Or perhaps something else is wrong such as the body to high versus the sub frame.
Do you have the correct spacers under the gearbox mount? If they are not present the rear of the engine will be slightly lower than it should be and the clearance under the rear carb reduced.
I don't know if mine is typical but I have only around 6mm static clearance below the rear carb jet cover and it does just tap the footbox sometimes when pulling away from rest .. never happens during normal driving so I haven't ever bothered to rectify it. Maybe I'll get around to it eventually.
S4 DHC
S4 DHC
- oldelanman
Does anyone have a good solution for rear Stromberg carb clearance concern on a Federal S4? I have just gotten my carbs back with adjustable jets replacing the fixed emission ones, and there is no way the rear one will fit as the jets now hang a full inch below the lower aluminum carburetor attachment. Luckily mine is LHD so I do have the option of hacking into the footwell for clearance. Are there any other options? Has anyone done this? What kind of a cup could I use to provide clearance and which could open inside the footwell for jet adjustment access?
If I remove the emissions intake manifold, could the carbs just bolt directly to the head? That would move the contact point inboard quite a bit - maybe enough to clear. Or would I still need some type of adapter to mount the carbs?
0005K Dick
0005K Dick
- 0005K
0005K wrote:Does anyone have a good solution for rear Stromberg carb clearance concern on a Federal S4? I have just gotten my carbs back with adjustable jets replacing the fixed emission ones, and there is no way the rear one will fit as the jets now hang a full inch below the lower aluminum carburetor attachment. Luckily mine is LHD so I do have the option of hacking into the footwell for clearance. Are there any other options? Has anyone done this? What kind of a cup could I use to provide clearance and which could open inside the footwell for jet adjustment access?
0005K Dick
With correct mounts it should clear, any chance you have engine mounts for the weber set up installed?
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
0005K Dick
Adjustable jets, or adjustable needles?
If you modified to adjustable jets, you may be forced to modify the footwell box to make room - and to be able to access what you need to adjust the jets.
I changed my Strombergs to the Euro spec (3322) with adjustable needles and fixed jets - no problem with them and the stock bodywork.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
I have had my carburetors modified to adjustable jets when I had them rebuilt. I asked for it, but I did not realize the consequences! - Oh no, you did just what I asked you to do! - The adjustment portion protrudes from the bottom of the carb quite a bit. I may have to have the carbs put back to fixed jets. - or start butchering the top of the footwell.
I expect that I have two identical new motor mounts (Stromberg engine type). I may be able to decrease the interference by using a special mount on the carb side of the engine designed for Elan use with Weber carbs. But that offset mount still may not be sufficient to provide clearance for the adjustable jet. Raising that side of the engine could also cause bonnet interference in the bonnet bulge or to the cam cover.
I'm going to try loosening the one engine mount, and jacking up the engine carefully to see how much movement I need to provide clearance.
Thank you all for the input!
0005K Dick
0005K Dick
- 0005K
Users browsing this forum: nmauduit and 15 guests
