Quick question about the standard fuel pump
WARNING - Thread Drift!
Richard,
I've been told exactly the same "somewhere"? It's why modern iridium plugs are a waste of money.
They will be fouled long before they "wear out".
I had a time when my car simply would not fire. Tried the old plugs on the gas ring ploy all to no avail. Sparks (at the lead) & fuel all seemed fine. Stuck new plugs in, at the advice of Rohan I seemed to remember, and it started immediately.
Obviously we need a supply of good old NOS Champion plugs!
Vince
RichardHawkins wrote:Vince,
With respect to your comment about plugs, Dave Walker of Emerald reckons that once a plug is fouled it never recovers. Something I read recently, but can't remember where, said that current plugs are not as well glazed as older plugs, the reason being that modern engines with electronic control of ignition and fuel never foul a plug, so resistance to fouling is no longer important.
Richard Hawkins
Richard,
Vince
- vincereynard
Less than ?2 each!
ww.sparkplugs.co.uk/review/product/list/id/6173/category/86/
- vincereynard
Back to the electric fuel pump part of the discussion: I have read in the past VW have a reasonably priced impact cut off switch, however my local dealer was less than helpful nor interested in finding a part number. Does anyone know either a part number, or year and model for such?
Please and thank you...
- jk952
I bought a Ford Mondeo fuel cut off switch, plenty on eBay (other sites are available!). I fitted it under the bonnet on the bulkhead near the bonnet catch on my Plus 2. Made a simple bracket so it was vertical with the car on level ground. Easy wiring for me as my electric fuel pump is under the carbs so simple wiring run. The pump has its own fused supply so I can pull the fuse to isolate it if I want to.
- Bigbaldybloke
jk952 wrote:Back to the electric fuel pump part of the discussion: I have read in the past VW have a reasonably priced impact cut off switch, however my local dealer was less than helpful nor interested in finding a part number. Does anyone know either a part number, or year and model for such?
assembled a few days ago:
Urs
ElanDNA - Second Gear
