choke cable
My choke cable is a solid single wire not multi strand, what do other people have? Just curious as replacing it with this type would probably be easier than trying to solder or braze in a multi strand bicycle type cable.
- Bigbaldybloke
Bigbaldybloke wrote:My choke cable is a solid single wire not multi strand, what do other people have? Just curious as replacing it with this type would probably be easier than trying to solder or braze in a multi strand bicycle type cable.
Solid wire. Someone may be able to swedge the new wire to the fitting.
Not sure if this thread is still open but I am trying to refit the choke cable in the new dash on my S2 but the tubular section that sticks out the back of dash with the nut/ screw bezel that tightens it to the dash does not line up with the hole. The solid tube that comes out the back of the dash is forced up over the top of the heater casing and when I tighten the bezel the inner part jams. The heater seems to be in the correct position with a 3/8” foam seal making an airtight joint. If I lower the front of the heater box there is a gap between the foam seal and the air intake plenum.
- ivan.wood
Users browsing this forum: ericbushby, nickspeed, Seamus, TBG and 9 guests
