Sealing Stromberg Balance Pipe
Hello
Finally mangaed to get the UK spec adpater flanges to replace my federal spec. Unfortunately they did not come with the balance tube which seems to be 1" OD tube
Was the original sealed with o rings or can I seal with good RTV or something else?
Terry
Terry
- terryp
Hi Terry,
"O" rings. Take a trip to your local "Auto Distribution" with the parts and they will find "O" rings that fit.
- alan.barker
The OD of the pipe is less than 1" to allow for the O ring ( mine measures 22.4 mm ) and there is a small flange near either end to retain the O ring in the recess in the adaptor block. It's shown in the parts list here .. http://www.lotuselan.net/wiki/EK_-_Engi ... y_Throttle
You could possibly make up something suitable using 22mm copper plumbing pipe with compression olives soldered on to make the flanges.
S4 DHC
S4 DHC
- oldelanman
