Re: Securing fuel tank breather pipe to roof.
Posted: Tue Nov 17, 2020 4:59 pm
I used 5/16 fuel hose as that was the size of the fittings on the Newton breather valves I used. Needed a reducer down in size from the main tank breather pipes that go to the filler neck. Took the vent pipe up the C pillar then back down through the original hole and terminated it in the wheel arch as per the original.
