Weber Airbox retaining bolts spec?
Just planning on fixing the original air box - help needed please?
Q) Can anyone confirm the screw thread size and type of the 3 retaining bolts, on the air box cover for a Sprint please?
Q) Seems to be some discussion as to it being either:- 1/4" UNC or UNF ?
Q) What are the length of each of the 3 no. bolts?
Q) Is there a rubber gasket around the air box between the metal and fibreglass joint? - does Anybody have a picture please?
Many thanks in anticipation !
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
also have two bolts on my s4......
obtained a gasket from sue miller [u-shaped] but when fitted it was too fat, so don't use anything....I suspect
a bit of foam strip would do.....
fred
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
I too couldn't make the "official" gasket rubber work so have used self-adhesive draught excluder on mine. My air box also has only two bolts. I bought some wing nuts from B&Q and welded them onto the bolt heads so that the box is easy to remove without tools.
TroonSprint - Fourth Gear
Hi Phil,
My Weber airbox is the three bolt fixing type.
Bolt lengths are :- 1,1/8" 1?" and 1,7/8" not including the bolt head.
No gasket on mine yet. Waiting to decide what to do, if anything. It does seem quite a snug fit without.
Eric in Burnley
S3SE DHC
Eric in Burnley
S3SE DHC
- ericbushby
Thanks for the replies Gents, much appreciated.
I too have tried the Sue Miller rubber U shaped gasket, but find it too thick and bulky, so have decided to use draught excluder foam, if possible.(Don't suppose it's the end of the World if one isn't fitted !)
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
For the gasket I used some U shaped thin rubber profile from Woolies, this one:
http://www.woolies-trim.co.uk/p-1772-ru ... usion.aspx
Bond it around the flange of the airbox on both faces - I used Tigerseal (light smear, leave to go tacky and then stick).
Leave the rubber trim with the bottom of the U sticking about 6mm from the lip of the airbox flange. When it's tightened up it all compresses beautifully to give and airtight seal.
This work really well, I was dead chuffed with it and it's good as new 3 years later and should last as long as the airbox.
Jon
Jon
- jono
Jon,
Great answer!
And thanks to all others who replied!
I knew someone would come up with away of fitting it - as they say " where there's a will, there's a way" !
So, when you say it is 6mm short of the "bottom" - do you mean it's not effectively pushed onto the tin flange of the air box backing plate completely? (Although glued in place? - Just fixed onto the first bit of Tinware, before the first shaped bend ?
Because, as you know, there appears to be too much rubber there, so that when the bottom IS fully seated onto the tin, it's far too large, and 'spills' out further than the tin shape. - as if the sides of the 'U' shape rubber section is too long or too big?
My issue is there just doesn't seem enough clearance or sufficient gap between the fibreglass part and the shaped opening of the metal back plate ?
Did you have to 'relieve' the fibreglass a little, to generate enough of a gap for the rubber to fit snugly between ?
Photo's ??
RSVP.
Phil.
Great answer!
Photo's ??
RSVP.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
