William2 wrote:Is it possible access-wise to remove the AC glass bowl type of fuel pump from an S4 Elan for replacement or repair? My car doesn't have any cut outs in the fibreglass transmission tunnel for access.
Yes, I've done it many times, as far as I know only the Sprint has a cutout in the f/glass with a grommet in it but it does not really help even with the grommet removed.
When you refit the pump just make sure you get the operating arm on the top of the cam and not under it.
Note: sometimes it is easier to remove the engine mounts to get the engine slightly over.
